Author Topic: failed to create empty document  (Read 1526 times)
dave.ruden
« on: October 29, 2010, 07:51:45 am »
  I just intalled EA (desktop edition), and on trying to run it, I get the error pop-up "failured to create empty document". The only option is to click OK, at which point, EA closes.
Has anyone else dealt with (and hopefully resolved) this problem?
I had the trial version installed, but it had expired.  I removed it prior to installing EA8.0 desktop.
Thanks!
---Dave.
mrf
Re: failed to create empty document
« Reply #1 on: October 29, 2010, 08:58:19 am »
That error usually means that one of the XML configuration files that EA is trying to read is empty.
Check for any XML files that are 0 bytes in length in:
- %PROGRAMFILES%\Sparx Systems\MDG Technologies
- %PROGRAMFILES%\Sparx Systems\EA
- %PROGRAMFILES%\Sparx Systems\EA\Config
If you can't find any, please send a registered support request to Sparx Support and we'll help you out from there.
Best Regards,
Michael
support@sparxsystems.com
« Reply #2 on: October 29, 2010, 05:29:49 pm »
This can also happen when your windows has run out of free GDI objects.
Close some windows (or restart the pc) and then try again in that case.
dave.ruden
« Reply #3 on: October 30, 2010, 08:07:17 am »
Must have been a 'resources' issue.  I rebooted and it works fine now.  Thanks to you both for your helpful replies!
---Dave.
