Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: alvinhsieh on July 12, 2006, 07:47:34 pm
HI,
'How can I use Package's Element to get Package's PackageGUID ???
'in some case The Package's Element's ElementGUID is not EQ. Package's PackageGUID ???
'EA 6.1-B791,JET3.5 , VB6
Public Function Check_Package(ByVal o_package As EA.package) As String
Dim pkg As EA.package
Dim C_package As EA.package
Dim x As Integer
Dim Elm As EA.Element
Set Elm = o_package.Element
If Elm.ElementGUID <> o_package.PackageGUID Then
Stop
End If
For x = 0 To o_package.Packages.count - 1
Set pkg = o_package.Packages.GetAt(x)
Call Check_Package(pkg)
DoEvents
Next
End Function
The package's Element attribute returns an element. This is to allow you to retrieve those properties of the package that are common to all UML elements. However, the package-specific features of the package should still be addressed using the Package element itself.
The can be a bit confusing, since both a Package and an Element can have a Packages collection, for example. As a rule of thumb - on which I might well be corrected by Sparx of other users - if the Package class provides the attribute or operation you need use that. Only use the Package.Element property if there is nothing offered at the Package level.
HTH, David
