Enterprise Architect => Bugs and Issues => Topic started by: Evgeny Florov on June 25, 2014, 06:22:07 pm
Title: Lost connections in sequence
Post by: Evgeny Florov on June 25, 2014, 06:22:07 pm
We use EA 9.3.935. Model is shared on SVN. Used many small "controlled packages" in model tree. After execution "Package Control/Get all latest" in all sequence diagramm was losts all message/call connections.
How we can resolve this?
Title: Re: Lost connections in sequence
Post by: qwerty on June 25, 2014, 06:34:41 pm
I guess you used classes in the sequence diagrams, not objects?
Post by: Evgeny Florov on June 25, 2014, 06:40:18 pm
All cases: in some diagramms - only components with provided interfaces;  in some - classes; in some classes and objects.
Post by: Geert Bellekens on June 25, 2014, 07:12:28 pm
That is a known issue for version 9.x
Apparently it should be a lot better in v10 and v11.
Workaround for v9 is to use only objects and never classifiers in sequence diagrams.
Post by: qwerty on June 25, 2014, 07:19:26 pm
Oh, this has been fixed? I would have preferred if the use of classes in sequence diagrams would have been disallowed from the beginning.
Post by: Evgeny Florov on June 25, 2014, 08:20:31 pm
Ok.
One more similar question. Also after "get all last" or "scan xmi and reconcile model" on all charts of components and communications z-order was broken and all connections became visible. It is a bug or we do something not correctly?
Post by: qwerty on June 25, 2014, 08:39:21 pm
Sounds like a bug, but I guess you will not see a fix for V9.3.
