Enterprise Architect => General Board => Topic started by: Tjerk on December 18, 2002, 05:18:08 am
Hi Geoff,
Now that I've worked some more with EA, I found some more things that do not work as I expect. Sorry for this long list, but I like EA so much that I really want to shave and optimise usability.
1. Model issues window: when I select multiple issues, right click and select Delete, only the last issue is deleted.
2. Model issues window: when I select one issue and press Ctrl-Del, the dimmed (gray, "semi" selected) item in my projecttree is deleted (have conformation disabled :-/). I would like to see that the highlighted issue is then deleted, more consistant.
3. Undo: (already mentioned by other users, but this is irritating me) I found bug 2, but, at first, didn't know what I had deleted in the projecttree, an undo is very welcom here.
4. Model Glossary: would like to be able to include this glossary as an RTF document in the resource view. I use this glossary in each of my produced documents, but now I have to all kinds of tricks to obtain this. Would like to be able to select the RTF template as well for this glossary.
5. RTF generation: if a relative location is given in the RTF document generation, it is relative to the "current" directory, while I would like to have it relative to the projectfile. If I e.g. first open Enterprise Architect and then open a project somewhere, the relative location is based on the EA executable path.
6. Update status: I would also like to be able to update the version of each child element.
7. Project root delete: if I have several project roots in one project, I'm not able to delete one of these project roots (all others have a delete in the context menu). This seems to be the first project root.
8. Project views: cannot drag and drop views.
9. Property window: when I make changes to notes using the property window and close the program, the notes are not saved.
10. Property window: the explanations of the selected item in the first tab takes to much space (i.m.o.). I would like these texts to appear in a tooltip / OnMouseOver.
11. Hierarcy view: the hierarcy view shows linked items on which I can doubleclick to get its properties. I would like to have a rightclick menu which includes "Show Usage", just like the project browser can.
12. RTF generation with resource tab: I would like to be able to auto generate all RTF documents in the list at once.
13. Boundary box font color: I cannot change the font color of a boundary box using the context menu. I now have to use the menubar.
14. Project browser: I would like to be able to include plain text elements in between diagrams, without any tags. I sometimes generate documentation that uses two diagrams in one paragraph. Text in between these diagrams makes a document more readable.
15. Auto tidy: if I move an object on a diagram, the connectors do not auto tidy. I have to slightly move each connector again to do this.
16. Custom line points: when I copy two objects with a custom line connector including an extra linepoint, that extra linepoint is not copied.
17. Stereotype icons: when I generate RTF documents with EMF embedded images, the stereotype icons become ugly (is this called grained? Too little DPI?). What image type is best for printed RTF documents?
18. Project bar: with the new bar on the top of the project browser window, I think that the project bar is more logically placed in that project browser bar.
I agree strongly. Relative paths are not really any more useful than absolute paths if they are relative to something that generally constant (EA installation directory.) This applies also to XML file paths for controlled packages as well.
Frank.
Wow Geoff,
You're fast ;D! After just a few days you managed to fix many of my reported bugs and even included some of the requested functionality.
I guess I will try (not so easy ;)) producing lists like the ones above to optimise and improve EA to (at least) my needs.
A question, once I saw in EA that aggregations could be joined to one forked tree (one diamond for n connectors), I cannot get that behaviour back. Someone got a hint on the subject?
Greetings and thanks again,
Tjerk
