Enterprise Architect => General Board => Topic started by: abcoates on December 27, 2002, 12:27:59 pm
Title: Adding check constraints to relational tables
Post by: abcoates on December 27, 2002, 12:27:59 pm
The documentation doesn't make it clear how to add check constraints to relational columns/tables.  I can create a check constraint, but I can't work out where to put the constraint test so that it appears in the generated DDL.
I am trying to limit a CHAR(1) column to take one of a set of 6 character values.  Thanks in advance for any advice,
   Cheers,
       Tony.
Title: Re: Adding check constraints to relational tables
Post by: abcoates on December 27, 2002, 02:24:20 pm
Ah-ha.  Worked it out.  The text of the "Notes" for the constraint is inserted as the SQL text of the check.  A similar thing happens to the "Notes" text for a trigger.
   Cheers,
       Tony.
