Enterprise Architect => General Board => Topic started by: Spaider on September 01, 2003, 08:02:52 am
Now I'm studying code templates and faced with unexpected trouble:
How can I generate quotation marks in resulting code?
(e.g. for generating string parameters).
Most common escape sequences doesn't work. I've tried \", \034, \0x22, I've tried doubling quotation marks. No positive results :(
Thanks in advance!
EA3.60 (635) currently does not allow escaping of the percent symbol (%), dollars symbol ($) or double-quote symbols ("). Presently, to escape a % or a $, it would have to be assigned to a variable as a string literal, viz:
$dollar_sign = "$"
$percent_sign = "%"
$something = $dollar_sign + "foobar" + $dollar_sign
This behaviour is described under "Planned Extensions" in the "Code Template Framework" section of EA's help.
To escape a double-quote in templates is somewhat different. You would have to output the double-quote as literal text.
For example - the Operation Body template in VBNet and Visual Basic has the following statement:
%opName% = ""
Which assigns a return value of "" if the operation is a function and it is of String type.
To achieve a similar result for setting default parameter values (for example), you could use the following "Parameter" template in VB and VBNet:
%PI=" "%
%paramDefault ? "Optional"%
%paramKind == "in" ? "ByVal" : ""%
%paramKind == "inout" ? "ByRef" : ""%
%paramKind == "out" ? "ByRef" : ""%
%paramName%
As
%PI=""%
%paramType%
%if paramType == "string" and paramDefault != ""%
="%paramDefault%"
%else%
%paramDefault ? "=" value%
%endIf%
NB: To use this template, you would have to ensure that your default string parameter value is saved without quotes.
Hope this helps.
Sam Mancarella
Sparx Systems
Hope this helps.
Unfortunately, it doesn't :(
I have slightly different situation. Here's an example: suppose, I want to notify that some property has changed. I had method NotifyPropertyChanged () for this. It takes one argument of type System.String (I'm writing in C#). I.e. the code snippet for property setter will be something like:
public double Amount
set
m_Amount=value;
NotifyPropertyChanged ("Abount");
How should I modify default template
$att=%opTag:"attribute_name"=="" ? "<unknown>" : value%
%if opTag:"writeonly" == ""%
$read="\tget{\n\t\treturn " + $att + ";\n\t}"
%endIf%
%if opTag:"readonly" == ""%
$write="\tset{\n\t\t" + $att + " = value;\n\t}"
%endIf%
to achive this?
PS Don't treat me lazy :) I've tried all variants I can imagine (not forgetting RTFM)
Hi Spaider,
I think the problem stems from not currently being able to use the quotes in variable definitions.
I may be misreading your intention here, but I think the following modifications to the default OperationBody template (with property stereotype) achieves what you are after.
1. Change the line:
to
$write="\tset{\n\t\t" + $att + " = value;"
2. Change the line that finally outputs $write. So:
$read
$write
becomes
$read
%if $write != ""%
$write
\t\tNotifyPropertyChanged("%opName%");\n\t}
%endIf%
3. Now when I generate the property I get:
public String Amount{
get{
return att;
set{
att = value;
NotifyPropertyChanged("Amount");
Admittedly, this solution is far from elegant, because the quotation marks could not used as part of the first variable definition for $write. We will be updating the template syntax ASAP to support use of the ", %, $, characters. For the short term at least, this will probably take the form of special macros- something %qt%, %pc%, %dl%. Then they can be mixed with variable references/definitions and literal text.
I hope this helps. Let me know if I've misread the problem.
Regards
Ben
Many thanks!
This time everything is OK.
Hi Spaider,
As of build 638, you can use the %pc%, %dl% and %qt% macros to get %, $, " characters respectively. You can use these with variable definitions or as a direct substitutions. Should provide a neater solution for getting the quotation marks into your property bodies.
Regards,
Ben
