Enterprise Architect => General Board => Topic started by: mber12 on March 11, 2004, 07:44:05 am
I used 'import directory structure' to reverse engineer a java package and I am seeing the class diagram but the diagram does not show relationships between the classes.
Did I miss a step or is there some otherway in EA to reverse engineer java class files such that the relationships are visible?
Thanks for any comments...
G'day g'day,
By any chance, is your diagram set to hide relationships?
Where can I tell if I am hiding relationships? I looked around but I can't find any option controlling that. Thanks.
OK - just found it in diagram propeties but the checkbox to hie relationships is not checked. I am probably using default settings for all diagrams. I merely imported the directory of java class files. Thanks for you help...
