Enterprise Architect => General Board => Topic started by: Andreas_G on March 30, 2004, 01:46:44 am
EA allows me to enter the parameters of a message in the Property Dialog of this message. That is OK.
But it seems, it's not possible to show this paramters in the Sequence-diagramm. :(
Is there a solution to show the paramters, or is the only way to enter the parameters behind the name of the message in brackets. That means the parameter field in the properties is useless. >:(
Make sure that you do not have "None" set as the Show Parameter Detail in the diagram properties.
hth
Bruce
Hi Bruce,
thanks for your answer.
I tried it, and the first time it don't work (my initial settings in the diagramm properties was "Type Only"). I changed it to "Full Details", and there was no effect in the diagram). :(
Then I searched for the problem. And I found it!!
It seems this "Parameter" feature works only for real existent operations of my class. For messages entered by hand, and paramters, entered by hand it don't work. :'(
Have you tried this?
bye
Andreas
