Enterprise Architect => General Board => Topic started by: Zulk on April 15, 2004, 07:27:28 am
I try to Import .mdb tabel to the Data Model Diagram,I select Project->Database Engineering->Import DB Schema From ODBC,then select a .dsn file link the .mdb file,after i selected the tables then press "OK",error message popup "Unrecognized Database Format...",what is worng I do?
I wish you would like to help me ,Thank you :)
Zulk, I think this may have to do with the version of Access you're using. There's an option to use the Jet 4.0 engine - Click on Tools|Options, there's a checkbox labeled "Use JET 4.0 - Requires Restart". Try that out.
