Enterprise Architect => General Board => Topic started by: tathata on June 18, 2004, 08:31:49 am
I have created my own language datatypes and code generation template for ActionScript 2.0.
I would like to setup a local directory for my "user defined language". When I open the local directory configuration window I only get options for setting up local directories for the built in languages.
Is there any way to do this or should this be a new feature request?
The dialogue currently doesn't support custom languages although it shouldn't be long until it does. ;)
There is a solution before then though.
The local directories are stored in a file called paths.txt in your EA directory. You can edit it directly to add paths for custom languages.
Simon
Excelent!
Thank you for all the help!
I have been using EA for a couple weeks now and it is really a great program and the support I have received from the forum has helped a lot!!
