Enterprise Architect => General Board => Topic started by: StefanR on July 19, 2004, 06:32:30 am
I've problems while reverse engineering a Delphi-class from a source-code file. It seems, as if recognition of the class-descriptions doesn't work properly as always the complete header instead of the pure text is added to the notes-field of my class if I start reverse engineering.
This is how my template (class notes) looks like:
Classname: %className%
Author: %classAuthor%
Date: %eaDateTime%
Description:
%WRAP_COMMENT(classNotes, "60", "", " ")%
This even happens, if a generate code for a class and use the same class for reverse-enginieering. The notes-field then contains the following:
============================================================================ Classname: ClassWithProps Author: Stefan Röck Date: 19-Jul-2004 15:18:12 Description: This is a comment.
Any suggestion?
Regards,
Stefan Röck.
Hi Stefan,
The parser doesn't have any way of knowing that you don't want all of that to go in the note field. What I suggest is that you modify your template to look something like this.
Date: %eaDateTime%
Description: }
That will import the way you want it. Even if it isn't quite as nice to look at what it produces.
Simon
Hi Simon,
thanks for your response. I'm afraid, your solution does not satisfy our needs, because we have plenty of documented source code and want to generate diagrams from that (and generate a RTF-documentation in a 2nd step).
Can you imagine of another template which parses the comments correctly (generating code isn't that important for the moment)? How does the parser work - does it only accept '{' or '}' as delimiters between "fields" or can one define other symbols?
A perfect solution would be if one defined the keyword "Description:" as a beginning tag so that the parser know where to start copying text for the class notes. Is that possible?
Thanks again,
Regards,
Stefan Röck.
