Enterprise Architect => General Board => Topic started by: Jeff Odell on January 06, 2005, 05:12:20 am
I m using the Fork/Join construct to identify concurrency in my Activity Diagrams.
By default these objects do not have a name. In order to tell them apart, I used the Property pane to assign a name in the Name field.
As soon I redisplay the Fork/Join in the diagram, the name appears briefly next to the Fork/Join in the diagram then disappears. Subsequently the Name property is gone from the Property editor.
Can we have:
1) The ability for the Name property to be persistent; and
2) the option for the name to appear or not in the diagram?
Thanks -
Jeff Odell
Does not look like this is intended. You should report a bug via the bug report...
Also I don't see a reason why the fork/join does not appear in the project browser (start, choice, etc. do appear).
I have reported it to Sparx as well.
jlo
Reply from tech support indicates this will be fixed in the next build. Thanks Sparx! :D
