Enterprise Architect => General Board => Topic started by: pj on April 05, 2005, 12:11:16 pm
Hi all! I'm evaluating EA Corp. Ed. in combination with StarTeam 2005. Setting up StarTeam and downloading and installing the SCC-interface is done and it works and it shows up in EA as an available SCC Provider. However when I have filled in the "Version Control Configuration"-dialog in EA I press save. I'm then asked to log on to StarTeam and that's no problem all projekt on the chosen server shows in the next dialog. After that I chose one of the projekts where I whant the models to be stored, fine. I fill out the next dialog to, with info about my chosen StarTeam-folder and press ok. Then it happens, EA (in the caption of the messagewindow) shows me a message saying
"DAO.Database[3075]
Syntax error in query expression "<VCConfigs><Config><Guid>klasserna</Guid><Type>0</Type><Provider>StarTeam Source Code control</Provider><ProjName><[Diagramarkivet]eatestIeatest>eatest\klasserna</ProjName></Config></VConfigs>".
I have tried several different ways through that last dialog and letting EA/SCC use existing StarTeam-servers/setting up new. Using existing paths/setting up new always ending up with this tiresome last messagebox.
Does anyone understand what it means? Any ideas how to get around/fix this?
Best Regards
/P.J.
