Enterprise Architect => General Board => Topic started by: VaS on May 12, 2005, 05:10:19 am
Title: Bug in DDL generating
Post by: VaS on May 12, 2005, 05:10:19 am
I have found a bug in DDL generating.
There's simple data model consists 3 tables (http://www.opcsoft.ru/download/123.zip).
EA can't generate right DDL from it.
It produces:
ALTER TABLE "HDA_FOLDERS" ADD CONSTRAINT "PK_HDA_STRUCTURE"
PRIMARY KEY ("I)
instead:
PRIMARY KEY ("ID")
You may try to have the same wonderful result using the file I mentioned above.
Title: Re: Bug in DDL generating
Post by: thomaskilian on May 12, 2005, 05:25:07 am
CREATE TABLE DB_VERSIONS (
ID int identity(0,1)  NOT NULL,
PRODUCT_ID smallint DEFAULT -1 NOT NULL,
VERSION int DEFAULT -1 NOT NULL,
STAMP datetime DEFAULT 0 NOT NULL
CREATE TABLE HDA_FOLDERS (
PARENT_ID int DEFAULT -1 NOT NULL,
NAME varchar(200) DEFAULT 'HDA Group' NOT NULL,
DESCRIPTION varchar(1000),
IS_LOG_GROUP smallint DEFAULT 0 NOT NULL,
MSTAMP datetime DEFAULT 0 NOT NULL
CREATE TABLE HDA_ITEMS (
HDA_FOLDERS_ID int DEFAULT -1 NOT NULL,
NAME varchar(200) DEFAULT 'HDA Item' NOT NULL,
MSTAMP datetime DEFAULT 0 NOT NULL,
DA_ITEMID varchar(500) NOT NULL
I'm using the latest 5.0 beta
Post by: VaS on May 12, 2005, 05:47:55 am
You didn't generate primary keys. The errors are there.
I'll try to use 5 beta immediately....
Post by: VaS on May 12, 2005, 05:54:28 am
:)) Where could I get the latest beta of EA? Unfortunately, I can't find it over the site.
Post by: thomaskilian on May 12, 2005, 06:28:14 am
You will find it on the registered users download area.
