Enterprise Architect => General Board => Topic started by: PeterHeintz on May 19, 2005, 03:49:21 am
Title: EA 5.0 crashes
Post by: PeterHeintz on May 19, 2005, 03:49:21 am
I am using EA with PVCS as version control system. Our project data is stored in an oracle data base. On some machines EA works, but sometimes a bit strange. So, controlled packages are sometimes not editable until a checkout has been started. Even if the checkout did not work afterwards we can edit the package. We have an other machine were EA just crashes without any message when we try to login.
Removing the VCConfigs in the registry prevent the crash but a manual new setup of the VCConfigs information within EA let to a crash again.
Title: Re: EA 5.0 crashes
Post by: HowardB on May 19, 2005, 09:55:29 pm
Peter,
We would like to track down and recitfy whatever is causing this problem to occur, however, we haven't been able to reproduce the problem here.
Would you please submit a bug report (or send an email) that includes a screenshot of the VCconfigs dialog, showing the settings you are using for the config that causes crashing.  It would also help if you sent us the string from the registry for the VCconfigs and if you can send the XML package file for the package you are placing under version control, that too would help.  Many thanks.
Your post also states, "We have an other machine were EA just crashes without any message when we try to login."  What is it that you are logging into here?  Are you trying to load a model that has security enabled?
Is the model stored in an Oracle repository and Oracle is prompting you to log in?  Can you please clarify under what circumstances EA is crashing.
Best regards,
Howard
[email protected]
Post by: PeterHeintz on May 23, 2005, 01:03:56 am
Hello Howard,
I will give you the information by email.
