Sparx Announcements => Latest News => Topic started by: sparks on October 12, 2004, 11:08:32 pm
Title: Version 4.1 - Build 739 Released
Post by: sparks on October 12, 2004, 11:08:32 pm
Removed Tagged Values tab page from Element, Attribute, Operation and Connector dialogs. All tagged values should be added and edited using the dockable Tagged Values Window (View/Other Windows/Tagged Values)
Modified move algorithm to correctly preserve layout of complex objects with deeply nested Parts and Ports, States and other Embedded Elements, together with their Custom Connector routing
Modified display of Test docked window to ensure it is correctly refreshed with currently selected object information when first shown or made visible
Modified XMI export to exclude "Encoding" attribute of XML instruction when Encoding string is set to nothing in Tools/options/XML Encoding
Adjusted tabular RTF output to scale with the user-selected width of the output page.
RTF Report dialog now saves Page setup with the template and no longer overwrites the default values
Fixed Find Object search dialog (Ctrl+F) so that "Scenarios, Tags etc" option works on MySQL repository.
Fixed bug on PostgreSQL and Adaptive Server Anywhere repositories when importing Reference Data having a null field.
Fixed bug importing table from MySQL where table name includes spaces.
Option added to Tools/Options/Object page to always show State Compartment divider under State name
Foreign Key dialog - allow saving only if there's an update of an existing FK or source and destination columns have been selected.
Modified XMI import to allow for embedded models in other objects.
Modified XMI export to exclude all diagram information when 'Export Diagrams' is not checked.
Resolved some compatibility issues in XMI 1.2 export to support Netbeans MDR (using uml2mof).
Fixed bug where packages exported to XMI may not have had their stereotype preserved.
Added option to Tools/Options dialog, Colors page. Allow showing of Project Custom Colors in Format Toolbar color palettes. Provides an aid to modeling with defined color set.
Fixed various bugs in the VB.Net parser
Restrained Part when dropped from Project Tree on to diagram to require Parent container is on diagram already
Added option (true by default) to Tools/Options/Object dialog ... duplicates Inheritance and realization links for an Edit/Copy (Ctrl+Shift+V)
Added check when saving diagram for possibility of diagram being deleted or reloaded through XMI. EA will reload containing package and re-show diagram if it still exists
Added check for missing elements when selected in tree - may occur on XMI import/export or element deletede by another user. Containing package is reloaded.
Modified check on moving element in diagram to preserve current element parent for deeply embedded elements.
Added "Const" tag type to list of supported tagged value types defined in Configuration/UML/Tagged Values. Default value must be set also.
Fixed issue with image scaling of embedded images in RTF documents when viewing under Word 97 or Word 2000.
Fixed Package drawing in diagrams to use alias names for package elements if available and the relevant option is enabled in the diagram
Modified "Paste as Link" function to include all related connection geometries between elements included in the copy
Fixed issue where operation throws tag was not updated during reverse engineering.
Added diagram option to display operation parameters by name only
