Enterprise Architect => General Board => Topic started by: StephaneGuerin on November 25, 2005, 04:25:49 am
I have an EAP file that includes some package under source control (CVS in my case). For some reason, I have to change the directory structure. Now when I open EA, I have a message telling me it does not find the "Working copy path YYY for VC config XXXX". So how I can tell EA where the repository can now be found.
Stephane Guerin
Well, not much answer on this one. Does it means the source control is fixed once for all the life of a EAP file?
Stephane Guerin
I presume you tried removing and reapplying (the new) version control to the package ?
I tried to remove that package from version control (without erasing it from my model). However, when I try to set it back under version control, the system refuse because it is already found under system control.
