Enterprise Architect => General Board => Topic started by: helmut on September 07, 2006, 04:22:32 am
how can I set a project default workspace perspective. I have several projects and when I open them, the workspace perspective "Project manager" is set by default.
I want to use "all" by default.
Greetings
Helmut
Helmut,
I reported a problem related to this a while ago. The solution is a bit tricky...
Do you have any MDG add-ins installed? In particular, do you have an early BPMN add-in? In the latter case update to at least version 1.1.1.0, which is the current version as of this moment. If that's your problem it should now be resolved.
Otherwise, on a bit of a long shot, try restting your main menu. You can do this from the EA main menu via Tools / Customize. Select the Menu tab and click Reset. This will clear some of your customized settings, but you can re-add them afterwards.
HTH, David
Hello midnight,
thank you. With the new BPMN Version it works.
Helmut
