Enterprise Architect => General Board => Topic started by: visean on September 11, 2006, 09:13:11 pm
Hi Folks,
I am getting the following error importing a WSDL file into Enterprise Archnitect.
Loading WSDL File....OK
Reading Header Information....OK
Creating WSDL Package : WMLS....OK
[StoreSoapBinding] Binding operations donot match [StoreSoapPort] PortType
Error in Operation : WMLS_AddToStore
Deleting Created Package....OK
The WSDL File can be found here http://staging.visean.com/unsecure/witsml_wmls.wsdl
If anyone has any Ideas, it would be greatly appreciated !
Regards
Mark
The culprit seems to be the comments under the WSDL PortType - these comments are causing the WSDL Importer to fail.
In the file you had specified, under the portType "StoreSoapPort", you will find the following 2 comments :
<!-- <operation> elements define the function signatures (operation name and parameters) and associate the input and output messages -->
<!-- parameterOrder attribute values must be separated by a single space -->
Delete these two comments and EA will import the WSDL successfully.
We will have this bug fixed for Build 798.
