Enterprise Architect => General Board => Topic started by: danm on December 05, 2007, 09:25:25 pm
Title: HOWTO: Remove MDG file elements
Post by: danm on December 05, 2007, 09:25:25 pm
Here's my original post - I figured out how to do it (read below)
  I'm several revs down the road on a new language support, but now I realized that what I had defined as Class stereotype overrides in my Code templates are really Feature overrides. But, I can't change them because they are defined in a MDG file (which I had created earlier and am using). You can only delete (and redefine) templates or stereotype overrides if they are current in your session.
Is there a quick way I can just edit the MDG file and change them myself, from Class to Feature? Also, what if anything does EA do differently between the Class and Feature stereotype overrides?
So if you have a mixture of MDG  elements you want to change, and new changes to that you want to keep - it's quite easy. For the elements you want to delete from a newly generated MDG file, simply leave them as 'unaltered' when running off the old MDG file. Then when you generate a new MDG file - since only the deltas get saved, you lose the one that's unaltered, as it's left in the OLD MDG file.
If that makes sense ...  ::)
