Sparx Announcements => Latest News => Topic started by: sparks on January 31, 2006, 08:36:13 pm
Sparx Systems are proud to announce that the Release Version 6.1 (build 786) of Enterprise Architect is now available for download.
Release Notes for EA 6.1 build 786
Improved handling of UNC paths on Adaptive Server Anywhere repository.
Added support for datatype mapping of character field > 255 to Memo field where Access is target database.
Ensured changes to connector tag values are propagated to shapescripts.
Added support for Python decorators.
Improved Delphi code parser to include parsing delphi properties containing qualified names and class references.
Improved VB.Net code parser handling of expressions and events.
Added support for generating both ends of bi-directional reflexive associations.
Added handling of connector end multiplicity ordered property to transformations.
Changed behaviour of Classifier typed tagged values to allow specification of valid types.
Resolved issue on Oracle and PostgreSQL repositories when using QuickLinker from a BPMN element.
Improved ShapeScript support for connector tag values.
Improved handling of invalid filenames in code generation.
Added support for documenting Object Run States in the RTF generator.
Improved DDL reverse engineering of SQLServer binary/varbinary datatypes.
Added sorting of drop table order for generating DDL for MySQL datamodel having foreign keys.
Improved support of SQL Server 2005 database reverse engineering.
Resolved different version issues when reverse engineering MySQL databases.
Added "Use <database" clause for generating ASA DDL generation..
Corrected primary key column generation for ASA DDL generation.
Improved handling of comments for ASA DDL generation.
Changed generated DDL for SQL Server script to use table alias when dropping foerign keys.
Ensured new UML Profiled elements added to diagram display their tagged values immediately
Ensured new UML Profile connectors added with Quick Linker show their tagged values immediately
Improved usability of the project security "lock to edit" mode, when combined with version controlled packages.
Ensure that current user's permissions are reloaded after making changes to user permissions or group permissions/memberships.
Resolved issue with saving version control configuration when using replicated EAP file.
Resolved issue with drop menus on Project Browser toolbar
Added option to "Copy a Base Project" to Start Page.
