Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: salayande on June 02, 2008, 07:26:12 pm
Title: Programmatic Export of XMI
Post by: salayande on June 02, 2008, 07:26:12 pm
Dear all,
I am writing an Add-In to programmatically export model contents as an XMI file. I plan to import this XMI into another development software.
This Add-In should access EA, enable the selection of model objects and export these objects as a single XMI file.
I would appreciate if someone has a piece of code that demonstrates how I may use the EA API features:
I want to be able to call the ExportPackageXMI from a button  and perform a number of functions as well:
private void button1_Click(object sender, EventArgs e)
            EA.IDualPackage ParentPackage = m_Repositroy.GetPackageByGuid("m_Repositroy");
            string fileName = "PegaBridge";
            long useDTD = 1;
            long formatXML = 1;
            long diagramImage = -1;
            string s = ParentPackage.PackageGUID;
            XMIType xmitype = XMIType.xmiEA11;
            long diagramUML = 1;
            ExportPackageXMI(s,xmitype,diagramUML,fileName,useDTD,formatXML,diagramImage);
private void ExportPackageXMI(String pguid, XMIType xmitype, long diagramUML, string fileName, long useDTD, long formatXML, long diagramImage)
            //Get UML, model element
            //Convert UML to XMI
            //Store XMI in input folder
Thank you in anticipation.
Segun
