Enterprise Architect => General Board => Topic started by: salayande on December 07, 2008, 07:29:11 am
Dear all,
Under General Improvements :
Modified viewing XML Schemas to use XML editor specified in the options.
Cannot find where this may be set. I generated a test schema and selected the "View" and anticipated the internal editor will display the XSD but I waited to nothing happened.
Given that this is a new release, I must be missing something.
I appreciate any help on this. Thank you.
Segun
The option for the editor to open is at Tools | Options | XML Specifications.
If you don't specify one, EA will use the default open command for XML documents on your computer.
