Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Jiri Urban on July 24, 2008, 01:49:46 am
Title: RTF report
Post by: Jiri Urban on July 24, 2008, 01:49:46 am
is there any way how to display forexamply only "basic path" scenario or same for some type of constrains in rtf report?
thank you for answer
Title: Re: RTF report
Post by: Dermot on July 24, 2008, 11:48:42 am
There is no direct filtering on the sub-element level of the RTF report generation. If you want to filter at this level it may be best to look into creating a query in the Advanced Search (ctrl-F).
Post by: Oliver F. on July 24, 2008, 09:59:29 pm
To round this up, as I believe it only partially solves the issue: You can create an advanced search filtering for basic paths.
Then you can assign this search criteria to model document as part of a complex document when generating documentation.
Meaning: You set several "chapters" by defining model documents made of either pacakges or aearch criteria (or both, though I am not sure about combing both). One chapter might be the result of the search rule extracting only the basic paths from your model.
I hope this helps.
Oliver
Post by: RoyC on July 25, 2008, 09:24:42 am
You don't combine them. If you have both in one Model Document, the RTF generator takes the package list in preference and ignores the search.
Post by: Jiri Urban on July 26, 2008, 12:41:55 am
thank you for your answers.
