Enterprise Architect => General Board => Topic started by: salayande on December 26, 2009, 11:48:21 pm
Title: Help Correct Script
Post by: salayande on December 26, 2009, 11:48:21 pm
Dear all,
I could not get my transformation scripts to do simple tasks in EA so I decided to learn the VBScript in EA.
To learn scripting in VBScript, I created a package with two classes with stereotypes set to the "Boy Soldiers".
I then wrote the script below to change the stereotype values to "BusinessEntity" but when I ran the script, nothing happened. Could anyone suggest what I may do to improve the script. Thank you in anticipation.
Option explicit
' The purpose of this script is to change the stereotype of all elements
' in a selected Package from current value to "BusinessEntity".
sub ChangeElementStereotype()
dim thePackage as EA.Package
set thePackage = Repository.GetTreeSelectedPackage()
      if not thePackage is nothing and thePackage.ParentID <> 0 then
      dim i
            Session.Output( "Changing the elements' stereotype" )
      'get elements
      dim elements as EA.Collection
      dim currentElement as EA.Element
      set elements = thePackage.Elements
            for i = 0 to elements.Count - 1
                  'get each element
                  set currentElement = elements.GetAt(i)
                  set currentElement.Stereotype = "BusinessEntity"
                  'update element stereotype
                  currentElement.Update()
            Next
            'refresh elements
            elements.Refresh()
            'report element updated
            Session.Output( "Done!" )
      else
            ' No package selected in the tree
            MsgBox( "This script requires a package to be selected" )
      end if
End sub
Title: Re: Help Correct Script
Post by: Takeshi K on December 28, 2009, 05:19:27 pm
Please add the following line before the currentElement.Update():
set currentElement.StereotypeEx = "BusinessEntity"
I think you need to set both the Stereotype and StereotypeEx.
Hope this helps,
Post by: salayande on December 29, 2009, 02:50:14 am
Thank you for your quick response, T-kouno, and especially over the Xmas break.
I inserted the line as advised but nothing happened. The updated script now looks like this:
Option explicit
      dim i
            Session.Output( "Working on package ")
      'get elements
                  'get each element
                  set currentElement.Stereotype ="BusinessEntity"
            Next
            'refresh elements
            elements.Refresh()
      else
            MsgBox( "This script requires a package to be selected in the Project Browser.")
      end if
End sub
Again, thank you for your help.
Segun
Post by: Takeshi K on December 29, 2009, 06:37:25 pm
I have removed unnecessary lines and now it seems to work fine.
My code is:
      dim thePackage
      dim i
      'get elements
      dim elements
      dim currentElement
             'get each element
      Next
End sub
Please copy the above script and paste it as EA's script (of VBScript).
My EA is 7.5.850.
Hope this helps.
Post by: salayande on December 29, 2009, 09:03:48 pm
Many thanks to you, T-kouno
regards
Segun
