Enterprise Architect => General Board => Topic started by: Mike Dorey on January 28, 2009, 11:58:16 pm
Hi all
I am trying to create a diagram which contains process boxes with 3 compartments in them. The first one would be the team carrying out the process, the middle one would be a brief description of the process including a unique ID, and bottom would be the name of the system where they are performing it.
E.g.
Logistics Team
1.1.2.6 Order
enters work pool
Order System
Does anyone know of a good way of doing this? I was hoping to modify something in UML Activity or BPMN diagrams but I havent found a good solution yet. Is there any way of making extra compartments available?
Thanks!
The Add-in event 'EA_QueryAvailableCompartments' may be available.
(You need to create an Add-in to show your original compartment)
To know detail, see the help file.
If each compartment is simple, ShapeScript is useful.
Hope this helps,
how can I print compartment value in shapescript ?
neuron
using: print("<insert property name here>")
