Enterprise Architect => General Board => Topic started by: dschmid2 on September 02, 2011, 06:46:32 pm
Hi there
I observed a strange behaviour in EA class diagrams. After modifying a diagram (adding class, modifying relation etc), the diagram is locked in a way, that i cannot move elements anymore. I can still add relations, add members to classes, but I cannot MOVE anything on the diagram.
After waiting some minutes, the diagram is unlocked in some magical way, and without any further notice, I can do everything again...
Did anybody observe this behaviour aswell?
I installed the latest version 909 and it still appears...
No sorry, never seen such behavior.
What kind of database are you using?
I'm using an EAP standalone file.
This is the way to reproduce the bug:
1. Press F12 on a class to show the C++ code hpp and cpp
2. Close the code editors
3. Try to move around the class -> it is locked !!!
4. After some time, it is unlocked again :-?
5. Repeat from step 1
Unfortunately I can't repro since my F12 is used for other things (running a VM). Maybe someone else can confirm, but if it is reproducible like that you should report it as a bug.
I can't reproduce it using those steps.
Can you reproduce it if you import the classes into a brand-new eap file?
