Enterprise Architect => General Board => Topic started by: st1led on January 14, 2012, 05:43:29 am
Hi everybody!
This might be a stupid question, but even through searching a bit I did not manage to find a solution. I'm drawing a Package Diagram in EA 9.2, but I only manage to have packages depicted in a compact view (http://www.udidahan.com/wp-content/uploads/ea2.png), where elements within packages are simply listed by type. What should I do to show packages in an expanded view (http://www.uml-diagrams.org/examples/package-diagrams-example-spring.png) where also relationships between elements within packages are shown?
Thank you in advance.
Regards,
Stefano
You need to do that manually. Unselect Package Contents in the diagrams Element properties. Then drag all packages onto the diagram. They are now blank. Expand as needed and drag their contents over the according package.
Thank you for your support, your solution worked great. I thought there was a way to do this automatically.
Regards,
Stefano
