Enterprise Architect => General Board => Topic started by: CorderBollie on March 30, 2012, 05:27:16 pm
Title: Debug with MinGW GDB
Post by: CorderBollie on March 30, 2012, 05:27:16 pm
Hello.
I tried to use the integrated debugger to record a sequence.
The program is compiled with MinGW including debug information and I have created a run script for debugging using GDB (comming with MinGW) as debugger.
Although I'm able to start the program in EA the debugger is not able to set breakpoints and I get warnings in the debug windows like:
 * Failed to find Breakpoint
 * Warning, all breakpoints failed to bind...
So the question is: is it possible to use MinGW-compiled programs with the debugger using a GDB configuration on Windows?
Title: Re: Debug with MinGW GDB
Post by: SomersetGraham on March 30, 2012, 11:59:28 pm
I have had this problem too,
I reported it to Sparx who are 'investigating' ::)
Post by: CorderBollie on April 04, 2012, 04:22:31 pm
Thank you for your reply.
I hope that 'investigation' will soon come to a solution.
Is there a way to follow the result of it via a bug/feature tracking system?
Post by: SomersetGraham on April 04, 2012, 05:24:23 pm
Unfortunately not >:(
Post by: Takeshi K on April 08, 2012, 08:48:31 am
Hello all,
Just for your information, I can set breakpoints and debug C programs on GDB, which complied by gcc of MinGW.
The EA help file says that GDB version 7 is necessary, and paths of source files do not include any spaces.
Hope this helps you.
Post by: CorderBollie on April 12, 2012, 04:38:17 pm
Hi t-kouno,
which GDB version are you using?
Mine is 7.3.1 with GCC 4.6.1 and EA 9.3.931.
I do not have whitespaces in the GDB and program path and also the program is compiled with debug information.
I installed MinGW not into the standard installation directory however I have added the path to the compiler and debugger to the PATH variable.
As I said GDB can be found by EA but can still not bind/find the breakpoints.
These are the settings of the debug script:
Platform->Debugger: GDB  (Run)
path:
remote:
port:12345
host:localhost
fetch:T
dumpgdb:
Tried both i.e. local and remote debugging using a local GDB-Server but nothing works.
Any more hints from you about how to get this running?
Post by: Takeshi K on April 12, 2012, 07:11:58 pm
Hi CorderBollie,
Mine is: gdb 7.2, gcc 4.5.2 and EA is 9.3.931.
I do not know the reason why the EA debugger can not find breakpoints, but I recommend to get a detail log and send the log to Sparx support team.
To get the log, enter path to 'dumpgdb:' paramerter like:
dumpgdb: C:\temp\debug.log
You may find some clue in the log to solve the issue.
Post by: CorderBollie on April 24, 2012, 04:37:08 pm
Finally I've found a way to make it work.
However I think there's a bug in the way EA handles the default directory setting of the analyzer script or in controlling GDB via MI2 protocol.
To make it work I have to place all code into one directory (no subfolders allowed) and compile and link the executable into the same directory.
After that debugging works like expected.
Post by: Eve on April 26, 2012, 09:45:22 am
Glad to hear you've got it to work.
The situation that I've used the GDB debugger has subdirectories, so that's not the entire problem.
