Enterprise Architect => General Board => Topic started by: Michel777 on August 02, 2013, 07:30:55 am
Title: Quality criteria of requirements
Post by: Michel777 on August 02, 2013, 07:30:55 am
I'm surprised, that there is no requirement attributes for quality criteria (clearly correct, complete, consistent, measurable, verifiable, modifiable and traceable).
I've defined eight tagged value pairs (fulfilled= yes/no, notes= explanation in case "not").
Is there a better way for hold the mentioned data ?
Thanks a lot,
Michel
Title: Re: Quality criteria of requirements
Post by: Helmut Ortmann on August 02, 2013, 03:53:46 pm
I would also do it with requirements. That's the porpuse of requirements.
Helmut
Post by: Michel777 on August 02, 2013, 04:33:14 pm
On the same way ?
Post by: Helmut Ortmann on August 02, 2013, 07:19:20 pm
I would define a checklist for the different quality criteria. In the requirements I would use the property Status or a tagged value to define a little workflow like:
Helmut
Post by: qwerty on August 02, 2013, 08:08:18 pm
Thanks a lot,
Michel
I don't see requirements as attributes of anything. A requirement is an element having attributes on its own and which is related via (stereotyped) dependency to other elements.
Post by: Gary on August 05, 2013, 08:03:24 pm
Hi Michel
To do what you want, go to Settings->Project Types->General Types
Select the Status tab and add the values you would like to use.
You can then select these values in the Status drop down on the properties page.
A bonus of doing this is that the same types are now available for all elements not just requirements.
Gary
