Enterprise Architect => General Board => Topic started by: Sunshine on February 09, 2015, 11:43:52 am
Thought I'd try out the Gantt view of a diagram and assign resources (people) to the elements. Trouble is I can't find a way to unassign a resource. Tried searching the help and scouring the menus but no luck. Any help would be most welcome.
I think it's currently only possible to delete an assigned resource via the Resource Allocation window. Right-click in the Gantt view and you should see an option like "Show Element Resource Allocation Window". From the Resource Allocation window you should be able to delete a resource currently assigned to the selected element.
Edit: The above instructions are for EA 12. If using EA 11, the "Resource Allocation" window was previously called "Project Management", and is opened via Element | Project Management.
Yeah forgot to mention using V11. That worked thanks Aaron.
