Enterprise Architect => General Board => Topic started by: AlTumes on February 14, 2015, 05:06:32 am
DDL Code Generation does not seem to work for me under EA 12. No matter what settings I chose, I just get a blank file generated.
Any suggestions?
Does it work with V11?
Yes - it did work with V11.
A
In that case you should send a bug report (and go back to V11). Someone else already suspected that Sparx test department seems to lack a bit of quality (to be polite) in relation to another issue with V12. From what I've seen in the past I would concur with that statement.
How are you doing this? There are two methods for generating DDL in EA12. Are you using Tools | Database Builder?
I've tried the 'old' route, i.e. right click on package -> Code Engineering -> Generate DDL, and the 'new' one, i.e. Database Builder -> Database Compare Tab -> Generate DDL. Same result in both cases.
I'm going to raise a bug report and go back to V11.
