Enterprise Architect => Suggestions and Requests => Topic started by: wadeh on December 17, 2003, 10:54:10 am
Title: Import DDL Schema from ODBC - requests
Post by: wadeh on December 17, 2003, 10:54:10 am
The "Import DDL schema from ODBC" tool should pick up table and column comments from the database. They are not showing up after running the tool on tables that do have comments defined (Oracle DB).
Also, the Synchronize existing classes option doesn't seems to work either. I ended up with duplicate objects of the same name/type in the folder with my diagram. What does this option do then?
Finally, the help screen for the Import dialog needs updating. It doesn't even cover all the options on the screen, much less help you understand what to do.
All in all, I think the import tool is too basic to be very useful in the real world. It might push me to look for another UML app if I can't easily keep my diagrams synched with the database. I need more detailed configuration options with the tool.
