Enterprise Architect => Suggestions and Requests => Topic started by: jasonab on May 11, 2006, 05:07:28 pm
Title: More flexible auto routing
Post by: jasonab on May 11, 2006, 05:07:28 pm
One thing I've noticed about auto-routing lines in EA is that the program is very picky about where it lets you place the lines on the classes.
For example, if I have to classes next to each other, there's no way to drag an association so that it links the bottom of one class to the side of another class (assuming one class is much shorter than the other).
It would also be nice to be able to move lines side-to-side without affecting where the line intersected the target class. For example, if I have a line that goes down from the bottom of a class and then left into the side of another class, moving the line to the right also moves it down. Id' like those behaviors separated.
Of course, I could do a custom line, but auto-routing makes maintaining lines when rearranging a diagram much easier. Frankly, this is one part of MagicDraw that I found much more flexible.
