Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: tonySparx on February 02, 2010, 01:44:40 am
Title: How to get the objectType from an ID
Post by: tonySparx on February 02, 2010, 01:44:40 am
Hi all,
I need to get objectType from an object ID, i.e. I have an object ID and I want to know what kind of object that is (otElement, otConnector and so on)?
I've already read the userGuide, but I suppose don't exists a method like " objectType getObjectByID(int ID)"...
Is there a way to implement my need in EA?
kind regards
Antonio
Title: Re: How to get the objectType from an ID
Post by: KP on February 02, 2010, 09:12:29 am
No, the ID isn't unique across all types.
Post by: Geert Bellekens on February 02, 2010, 06:14:21 pm
Antonio,
In that case you'll need to use the GUID property.
That would be (by its nature) unique amongst all objects.
Post by: mrf on February 03, 2010, 08:54:15 am
You do have two options in the following scenarios:
1. If it's the currently selected item you can call GetContextItemType()
2. If it's the currently selected item in the tree you can call GetTreeSelectedItemType()
Post by: tonySparx on February 06, 2010, 09:30:17 pm
Antonio,
Thanks to all for help,
Geert, would be unique or IS unique? :D I've not found anything about this difference on the EA userguide...
Post by: Geert Bellekens on February 06, 2010, 10:53:18 pm
Tony,
"should", but with EA you never know ;)
Post by: Paolo F Cantoni on February 07, 2010, 12:37:58 pm
Antonio,
As a Data Architect, Tony, I learnt a LONG time ago that the term unique MUST always be accompanied by the context in which one is asserting uniquenesss...
For example, within a table such as t_object, the Object_ID is unique, but not across tables.  A GUID or UUID is notationally unique but only if you don't assign it to more than one entity.
Personally, I'd probably create a t_GUID table that had the GUID as the primary key, then the entity type (it was assigned to), and the entityID.  That way, I'd end up with a self-consistency mechanism that would assist in ensuring I didn't allocate the same GUID to more than one entity  (not that, so far, EA does).
