Enterprise Architect => Suggestions and Requests => Topic started by: rezaTech on September 09, 2007, 07:56:25 pm
hello
i am new to EA and currently using the trial version.
is it possible to give different users different type of prmission? i have few scenerios. some of them are:
1.mr.x will have read permission to Use case,sequence diagram and write/modify permission to class diagram.
2.mr.y will have only testing permission.
3.mr.z will have only code generation permission.
The available list of permissions for users is at http://www.sparxsystems.com.au/EAUserGuide/index.html?permissionlist.htm.
You can create a user with only permission to code generate. The other two users you have used as example appear to require finer control of permissions than EA provides.
thank you simonm.
