Enterprise Architect => Suggestions and Requests => Topic started by: effiban on January 15, 2008, 05:27:58 am
Title: Java Generics
Post by: effiban on January 15, 2008, 05:27:58 am
EA 7 does not provide full support for Java generics. There are workarounds, for example in the following link:
http://bedla.czech.googlepages.com/How.to.create.generics.in.EA.pdf
I suggest that a more comprehensive and intuitive solution be implemented for the next release.
Effi
Title: Re: Java Generics
Post by: Martin Terreni on January 15, 2008, 07:31:44 am
I think it is very important if you plan EA to be used for full round trip programing.
Post by: effiban on January 15, 2008, 08:15:44 am
That's right - and even if you only want to import from existing code to a diagram, you would still lose some generics information in the current version.
I would like to point out one more issue as well, which is not Java-specific but relates to templates in general: The template arguments of a class or interface are not shown in the diagram (only template parameters are). This is important information even at the design level, and I suggest it be added to the display as well.
