Enterprise Architect => Suggestions and Requests => Topic started by: DanG83616 on May 23, 2008, 10:23:20 am
Is there a way to specify a local path for linked files?
Web links don't quite meet my needs and I use p4 to version control the documents and, by side effect, distribute them. If I could define a local path type then I could link to file just like I link to source code.
Example:
A visio drawing has a very useful graphic in it and I'd like to link it to a use case element. The visio file is checked into perforce and I see it at D:\dev\ProjectX\Models\Requirements\foo.vsd. Other colaborators see it in different local paths but always under ...\Models\Requirements. Thus, I'd set MODEL_REC_DOCS to D:\dev\ProjectX\Models\Requirements. Other colaborators would set MODEL_REC_DOCS according to their local tree. Thus, the links would work for us all.
Dan
I want to second your request for this functionality. It will be very useful to have the possibility to use local paths everywhere not just for generated code files.
I'm having good results using EA as a tool to implement specific practices in CMMI RD and REQM process areas. This feature would make it a lot easier to link to artifacts created outside of EA. In my case, none of the user-generated artifacts are EA elements.
