Enterprise Architect => Suggestions and Requests => Topic started by: wikitect on July 01, 2009, 10:10:24 pm
Search provides a tabular set of results and yet is not able to export to CSV (from which to build a table) - unlike the Relationship Matrix.
The documentation options are very limited and there's little control over the presentation so it would make a lot of sense to be able to export and re-import the CSV into something with more control over presentation.
This ought to be an option for any tabular view or set of results produced within EA.
You can create a RTF report with the results of a search.
Well, create a simple RTF Style Template with only [name] and comma, and you obtain your CSV file (you will need to rename the .rtf extension by .csv...)
Hmm.
The only options from the search results are:
Documentation > RTF report for Each Selected Item
Documentation > RTF Report on Selected Items
In both cases I then get the error that the selection does not contain any element for which RTF documentation can be generated.
Not sure how then to create a report.
Try Ctrl-A to select all, then in the context menu select: Copy to Clipboard.
Open say Excel and Ctrl-v to get the full format - save to CVS.
Hmm. I'm using EA on a Mac via Crossover. When I select all the search rows and paste into Notepad I precisely nothing. If this were going to work I'd have hoped to get text and some form of column separator. At the moment therefore I can't see how this might work.
Even if it works, some "exprt results to CSV" would be nice (and it is not that mush work...)
Indeed.
As I've just found out (this time using EA in a VMWare Fusion Virtual Machine) ... where the copied search text includes a carriage return the paste into Excel fails as it then places the subsequent paragraph into the wrong column so the tabular report gets jumbled. :'(
Not a viable solution. More a temporary and partial workaround.
