Enterprise Architect => Suggestions and Requests => Topic started by: Mike Buchan on January 08, 2010, 05:23:13 am
I am working on a system which involves a MySQL database. I have been working the schema in EA. However, I have run into some instances where I need a data type which is defined in MySQL but not in EA. This means that I must manually modify the DDL to use the correct data type (MEDIUMBLOB is a major one for me).
It would be nice if either all data types defined for a given data base were available in the combo box or the user is allows to type in a missing data type.
Hello Mike,
I suggest you look at:
http://www.sparxsystems.com/uml_tool_guide/data_modeling/dbmsdatatypes.html
That works.
Thank you for the quick response.
