Enterprise Architect => Suggestions and Requests => Topic started by: marcelloh on January 12, 2011, 03:11:16 am
I like to see more examples on how to use this.
I tried some things, but I can't just keep on trying.
Is there a database structure somewhere that would help me?
I would like to search on objects of a specific type, with some specific tagged values. I did look in this forum, but didn't find much help.
There's no "real" documentation but "real programmers" won't need that anyway. What you can do is to import the DB structure of EA by Code Engineering/Import DB. That way you have all tables and columns as a class model. It will help you to find the required data.
Of course you need to guess a lot. Your concrete question: t_objectproperties contains the tagged values along with the corresonding object id.
Good luck,
Thanx for your answer,
I found that out allready, but i can't figure out how to map the tagged value of a requirement to the requirement itself.
Guessing is not good... what if i guess wrong and I display some unpredictible data and assume I did good.
No... I must be 100% sure.
The manual is very unclear on this matter as well...
Marcel,
This query returns requirements that have a certain tagged value:
select o.ea_guid as CLASSGUID, o.Object_Type as ClassType, o.Name as Name,tv.Property as Key,tv.Value as [Value],package.name as [Package Name]
from ((t_object o
inner join t_objectproperties tv on tv.Object_ID = o.Object_ID)
inner join t_package package on o.package_id = package.package_id)
where tv.Property like '*<Search Term>*'
and o.Object_Type = 'Requirement'
Take care of wild chars. They are depending on the database.
Q. is right, this query will work on MSAccess .eap files.
If used on a "real" database you should use the (SQL Standard) '%' wildcard.
If you are saving this as a SQL Search in EA, you can use the #WC# macro to automatically insert the correct wildcard character for the database type you are connected to. See:
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/navigate_search_and_trace/creating_filters.html#sql
Thanks Aaron, I didn't know that.
This proves it, we can always learn something new :)
So i did try Geert's option (Thanks/Bedankt!).
I see however no requirements, only other stuff.
The result-view (inside the model-search window) doesn't show me
the coloms for the query. Am I doing wrong?
Can a EA expert give some working examples on this matter?
The trick is, that I want to find certain requirements with the same tagged value, So i have a kind of #d model of all my requirements, and I just can look at them the way I want to.
Basically , I just make a kind of vertical slice through all of them, and focussing on a certain keyword. Let's say "Legal". So I could easily find all requirements that have to do with "legal".
from (t_object o
where o.Object_Type='Requirement'
Just a simple one... That give a good result in MsAccess, but a strange result in EA. (I see all kinds of notes, and only one requirement.)
I just found out, that this was because I pressed RUN (instead of another option to run the sql statement).
So this is one that works:
where o.Object_Type = 'Requirement'
and tv.Value like '*legal*'
(If I change the *-sign into the suggested #WC# then it doesn't work.)
So after testing it, I changed the hard coded value "legal" into <Search Term>. Saved the query and it works. Hopefully I saved some people some time.
Marcel,
I tried the #WC# macro on one of my other searches, and it seems to work just fine. (maybe its a version thing? I'm on 8.0.856 now)
Here's the SQL code I tried:
select a.ea_guid as CLASSGUID,'Attribute' as CLASSTYPE,a.name as Name, a.Type as 'Type', class.name as 'Class Name'
,package.name as 'Package Name' ,package_p1.name as 'Package level -1',package_p2.name as 'Package level -2',package_p3.name as 'Package level -3'
from (((((t_attribute a
inner join t_object class on a.object_id = class.object_id)
inner join t_package package on class.package_id = package.package_id)
left join t_package package_p1 on package_p1.package_id = package.parent_id)
left join t_package package_p2 on package_p2.package_id = package_p1.parent_id)
left join t_package package_p3 on package_p3.package_id = package_p2.parent_id)
where a.Name like '#WC#<Search Term>#WC#'
I just published a blog post about
Harvesting the power of EA’s SQL searches (http://wp.me/p1dEib-1r)
I tried the #WC# and it works. (Must have been a typo).
I've just read your blog Geert. These are some nice initiatives.
If someone has other nice sql searches, then please publish :-)
So people with limitid sql knowledge could benefit.
Speaking of which:
t_propertytypes has all my default tagged values.
How can I find out, if there are requirements that are missing those.
(So i would like a view, where he would mention a tagged value, and the requirment that hasn't got that tagged value)
Has anyone done this?
Try this one:
select o.ea_guid as CLASSGUID, o.Object_Type as ClassType, o.Name as Name,package.name as [Package Name]
from (t_object o
where
not exists (
select * from (t_object o2
inner join t_objectproperties tv on tv.Object_ID = o2.Object_ID )
where tv.Property like '#WC#<Search Term>#WC#'
and o2.Object_ID = o.Object_ID )
and o.Object_type = 'Requirement'
Hello Geert... This one is also a beauty, but gives me
the requirement with the packagename.
I need something like this:
t_propertytypes.property t_object.name
The first is the standard tagged value
the second is the requirement that is missing that tagged value
So I have in this overview all the Req's that are not complete :-)
Marcel,
I'm sure that's possible as well, but that would take me a bit too long to figure out. Sorry :)
Now at https://bellekens.com/2011/01/14/harvesting-the-power-of-eas-sql-searches/
When opening the link, I get a message that it is deleted.
That's why skiwi has posted the new link.
