Enterprise Architect => Suggestions and Requests => Topic started by: g.makulik on November 27, 2012, 11:46:24 am
Wouldn't it make sense to provide preprocessor macro setting also for C language?
There are surely a lot of compiler implementation or framework specific definitions, that should be ignored when C code is imported/synchronized.
Opinions anyone?
Best reagards,
Günther
I'm reasonably sure that they are shared. So the question is: Is there a use case where they need to be different?
If they're shared from the definitions for C++ everything will be fine.
Didn't check that so far, just stumbled over the drop down, that only offers C++. It should display better 'C/C++' then.
Best regards,
Günther
macros are working fine for C. I tested it.
Kind regards,
Helmut
Also confirmed this meanwhile.
Thanks Helmut
