Enterprise Architect => General Board => Topic started by: ssands on January 14, 2016, 07:33:14 am
Title: How to show partial stereotype name?
Post by: ssands on January 14, 2016, 07:33:14 am
I have some elements that are stereotyped "TOGAF::Capability".
This is also how it shows up on my diagram.
I want to show the stereotype but I would like to show it as "Capability" without the "TOGAF::" prefix and it complicates the message for the end user.
Is there a way to do this other than creating my own Capability stereotype?
Thanks!
Title: Re: How to show partial stereotype name?
Post by: qwerty on January 14, 2016, 07:59:27 am
You need to install the TOGAF MDG. That will interpret the stereotype and display the correct picture.
Post by: ssands on January 14, 2016, 08:07:18 am
It is installed and active. That is how I was able to choose that stereotype.
Or perhaps I'm missing something...
Post by: ssands on January 14, 2016, 08:19:07 am
Further clue:
This happened when I changed the stereotype from something else.
If I create a new element with the TOGAF Capabiltiy then it shows how I want.
Post by: ssands on January 14, 2016, 08:32:43 am
How to duplicate the issue:
Create an element with stereotype of Business Function (from TOGAF profile).
Change stereotype to Capability (From TOGAF Profile).
Stereotype now shows as TOGAG::Capability.
Create new element with stereotype of Capability from TOGAF profile.
Stereoptype shows as "Capability" without the "TOGAF::" qualifier.
Post by: qwerty on January 14, 2016, 08:54:52 am
I don't have the TOGAF MDG so I can't verify that. Check if the Business Function and the Capability have the same meta type. If not, then this might be the cause. If they are the same you should probably report that as a bug.
Post by: KP on January 14, 2016, 09:10:07 am
^ this.
TOGAF::BusinessFunction extends UML::Activity and TOGAF::Capability extends UML::Class, so they aren't really substitutable.
Post by: ssands on January 14, 2016, 09:21:17 am
^ this.
Yes! Thank you!
Related question: so far the only way I know to determine what extends what is to do an csv export and look at it.
Is there a better way?
Post by: KP on January 14, 2016, 09:37:27 am
Create one and remove its stereotype, see what's left.
Post by: ssands on January 14, 2016, 12:12:14 pm
Thanks!
