Enterprise Architect => Bugs and Issues => Topic started by: Paolo F Cantoni on January 28, 2016, 02:59:58 pm
Title: printwrapped doesn't recognise "#TAG:<tagname>#"
Post by: Paolo F Cantoni on January 28, 2016, 02:59:58 pm
If you try to use   printwrapped("#TAG:condition#"); it will fail to run the substitution macro and will emit the text: #TAG:condition#
print("#TAG:condition#");  works fine, as documented
Reported,
Title: Re: printwrapped doesn't recognise "#TAG:<tagname>#"
Post by: Eve on January 28, 2016, 03:18:56 pm
Just tested and it did.
What build of EA are you on? There was a bug fixed recently where wrapping was done before substitution, which meant you could get similar behavior if the element became too narrow.
Edit: Just checked. The fix hasn't been released yet, so that's probably your issue.
Post by: Paolo F Cantoni on January 29, 2016, 11:03:11 am
For the record, it was build 1226.  And it's on a connector shapescript, specifically I'm setting the LeftBottomLabel.
