Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: [email protected] on March 12, 2016, 03:11:34 am
I am trying to use the MARTE UML profile in EA but I have not succeeded so far.
I have been able to import the official MARTE profile XMI from http://www.omg.org/spec/MARTE/20100801 into EA. It seems to show up correctly although it does, of course, not contain any diagrams. The imported model shows a tree of nested packages and profiles as it is defined by the OMG standard.
At this point I got stuck. If I try to export this model as an EA profile it is simply empty. From the EA documentation I have learned that profiles in EA must not contain nested packages or profiles. So the structure of the imported MARTE model is obviously my first problem.
I have also moved some of the stereotypes and metaclasses to the top-level MARTE package. If I now export this package as a profile I can import it again and do, acutally, see some profile entries. But they do not show the correct name of the stereotypes. If I am not mistaken, EA is showing the next stereotype upwards in the MARTE generalization hierarchy.
Finally, I do not want to put all of the MARTE stereotypes, etc. into a flat package. There are just too many of them. I would like to keep them separated into multiple profiles. The EA documentation is mentioning that it is possible to store multiple profiles inside the same profile package. However, I cannot find any documentation how to correctly create such a setup.
I would appreciate any help on this.
I was able to create a profile from one of the sub-packages with no issue. It's probably a bit tedious to export all single profiles and make a MDG, but that's just laborious. It takes some effort to create an EA MDG, but it's likely possible to do so with the MARTE profile.
I have been afraid that this is the answer ::)
Unfortunately, I am still not able to make it work completely. I have exported all leaf profile packages from the MARTE import and bundled them into an MDG technology package. However, when I import this MDG technology into another project and try to apply a stereotype from the MARTE profile to a model entity I only see a subset of the MARTE profiles in the selection dialog. Any ideas?
This depends on how you have created your MDG. When importing it via the Resources window you should see all the single profiles. Is that the case?
MARTE profile will be part of EA15 (and is already part of EA15 beta)
