Enterprise Architect => Bugs and Issues => Topic started by: Paolo F Cantoni on June 30, 2016, 09:49:25 am
Title: 1301: Realisation vs Realization for QuickLinker
Post by: Paolo F Cantoni on June 30, 2016, 09:49:25 am
Yes Geert, the old realisation vs Realisation issue rears its ugly head again...
We have developed a QuickLinker Generator that allows us to take the ArchiMate 2.1 & 3.0 relationship tables (located at the end of the specifications), and generate the appropriate QuickLinker entries for the MDG.  This is being done at the same time we're testing 1301.  As we know the QuickLinker will "silently" fail - so when things didn't "pan out" we sat glum faced...  We know how hard it is to debug this stuff!  :(
Our generator uses a whole pile of preferentially integral tables to ensure that everything is CONSISTENT!  Initial visual inspection of the gernated file showed that structurally it was correct.
Eventually we tracked it down to the relationship type for Realizations...  Everywhere else in EA (as far as we can tell) you have to set it to the incorrect (Realisation), BUT in the QuickLinker it has to be the correct (but inconsistent) Realization! ???
Sparxians, you need to change the QuickLinker processing to allow BOTH.
My tag line applies here...
Reported,
Title: Re: 1301: Realisation vs Realization for QuickLinker
Post by: Geert Bellekens on June 30, 2016, 12:48:05 pm
Whenever I deal with Generalization, whether it is code, or a query, or a template, I always make sure to include both variations just be be on the safe side. (I don't want to bother check which variation applies in these circumstances, and whether or not there might be ancient erroneous instances lurking around)
Same thing with Association and Aggregation
Post by: Paolo F Cantoni on June 30, 2016, 02:10:02 pm
Unfortunately with the QuickLinker, you can't.  If you put the wrong one in, everything AFTER than bad entry is ignored!  :'(
That's a second order defect!
If I get a confirmatory response from Sparx, I'll add that.
