Enterprise Architect => Bugs and Issues => Topic started by: bITs.EA on July 14, 2016, 12:15:25 am
Title: SQL search with 'union'
Post by: bITs.EA on July 14, 2016, 12:15:25 am
Hi
I'm trying to do a UNION search, but I don't get any results. The 2 separate queries give me the expected results, but using UNION doesn't seem to work. EA isn't giving an error either.
(SELECT p.Name AS 'Process', o.stereotype AS 'ElementType', o.Name AS 'Element', null AS 'Opgenomen in Project?', null AS 'Owner?'
FROM t_object AS o INNER JOIN t_package AS p ON o.package_ID = p.package_ID
WHERE
o.package_ID IN (SELECT package_ID FROM t_package WHERE parent_ID = (SELECT package_ID FROM t_package WHERE name = 'Bedrijfsleiders'))
AND
o.StereoType <> ''
ORDER BY 'Process', 'ElementType')
UNION
(SELECT d.Name AS 'Process', 'Document' AS 'ElementType', o.name AS' Element', null AS 'Opgenomen in Project?', null AS 'Owner?'
FROM (t_object AS o INNER JOIN t_diagramobjects AS do ON o.object_ID = do.object_ID) INNER JOIN t_diagram AS d ON do.diagram_ID = d.diagram_ID
WHERE o.package_ID = (SELECT package_ID FROM t_package WHERE name = 'Documenten')
ORDER BY 'Process')
Can someone give me some advice?
Grts
S
Title: Re: SQL search with 'union'
Post by: qwerty on July 14, 2016, 12:37:57 am
Surely depends on the DB you use, I guess.
Post by: bITs.EA on July 14, 2016, 12:59:45 am
It's SQL Server DB. I've found my error: ORDER BY can't be in the first query.
Working SQL query:
WHERE
AND
o.StereoType <> ''
UNION
ORDER BY 'Process'
