Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Ed on August 19, 2010, 09:54:45 pm
Hello, I'm looking to simply load an EAP and generate a report using Java.
I would like to automate this process as a part of my build process.
I followed the directions about using SSJavaCOM.dll.
However I recieve the following error message when I try to run a simple test:
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Windows\System32\SSJavaCOM.dll: Can't load IA 32-bit .dll on a AMD 64-bit platform
It would appear this dll does not support 64 bit operating systems.
Is there a work around or a 64 bit version of this dll I can use?
Ed
No, EA doesn't exist in 64bit country.
Thanks for the quick answer.
Any alternatives to automating the creation of the HTML report on a 64 bit host?
I'm assuming i'll have the same problem with C# on 64 bit... :(
Compile as 32bit?
To integrate with Java on a 64 bit platform you need to install the 32 bit Java runtime and integrate with it instead of the 64 bit runtime.
There is no issue with C# unless the use x64 bit CPU flag is explicitly set - the default is 'Any Cpu' (at least in visual studio). I do most of my development in C# on a 32 bit machine but deploy to 64 bit servers with no issues.
Stan.
