Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: tim-southerland on September 16, 2010, 05:00:44 am
Where would I begin if I wanted to automatically import a matrix (.csv) that described a large array of BPMN message flows/ activities?
Ultimately, I would like to generate a BPMN diagram from the imported data.
I'm new to Sparx EA & its automation features. I am a system integrator with java, VB and C++ software development background.
Tim,
I would first look at some addin examples.
There are basically three locations to find those:
- the community site (http://community.sparxsystems.com/resources/scripts), the excel vba importer (http://community.sparxsystems.com/resources/scripts/simple-vba-excel-ea-importer) might give you some inspiration
- The resources section (http://www.sparxsystems.com/resources/developers/autint.html) of the main website
- The examples provided with the installation at C:\Program Files\Sparx Systems\EA\Code Samples
If you run into trouble, use the left top "search" in this forum. There are a lot of question with useful answers about all things API.
Have fun
Thanks Geert,
I saw your VBA example. Unfortunately, I don't have excel loaded on the modeling machine so I am unable to utilize an automation interface using VBA. From what I can tell, this means that I will need to write an EA script, develop an add-in or develop an external application that interfaces with the EA activeX objects,
I'm looking for examples that demonstrate a way to import a .csv with VBscript and an example that manipulates connectors. (most local script examples demonstrate manipulate of elements other than connectors). I found that one of the C# examples located in "..\Sparx\EA\CodeSamples\C#_Samples" that has some file I/O functionality and some code that manipulates connectors. This would be a good place to start, but I've run into some hiccups.
I have Visual Studio C# express 2010 w/ .Net v4. Is the Automation Interface (interop.ea.dll) compatible with this version? Seems like the code examples are unable to find essential objects in referenced .dlls.
Tim,
I've used that same version of visual studio before to create EA addins, so that can't be the problem.
What issues are you facing exactly? Maybe a code sample could help to see what is going wrong.
