Enterprise Architect => Automation Interface, Add-Ins and Tools => Topic started by: Bojan Knezovic on November 17, 2010, 06:52:09 am
Title: Trace between elements
Post by: Bojan Knezovic on November 17, 2010, 06:52:09 am
Is it possible to start (using VBScript) with one EA.Element and list all other elements that it is linked to? For example I'd like to start with a Requirement and list all use and test cases that are linked to it in any way. It would be awesome for traceability purposes..
I could list all elements in a package but I am having a hard time navigating through Collections (actually I don't know which collections exist at all) and identifying the correct element types. And I can't find any reference either.. so, any help is appreciated.  ;)
Thanks.
Title: Re: Trace between elements
Post by: Eve on November 17, 2010, 08:13:44 am
Reference - http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/reference.htm
Loop over Element.Connectors for a start.
Post by: Bojan Knezovic on November 17, 2010, 08:19:52 am
Yeah, I've been just looking into it but I can't see any GUID or something that I could later use to search for the other element...
http://www.sparxsystems.com/enterprise_architect_user_guide/8.0/automation_and_scripts/connector.html
for each currentElement in currentPackage.Elements
if (currentElement.Type = "UseCase") then
for each elem in currentElement.Connectors
..and now what?  :-?
Post by: Geert Bellekens on November 17, 2010, 05:20:14 pm
Bojan,
I think it should be more like this:
foreach (EA.Connector con in currentElement.Connectors)
    EA.Element linkedElement;
    if (con.SupplierID != currentElement.ElementID)
           linkedElement = myRepository.GetElementByID(con.SupplierID);
    else
          linkedElement = myRepository.GetElementByID(con.ClientID);
PS. This is C# syntax, you'll have to translate that to VBScript syntax.
